BQ25713EVM-017: Configuration file loading doesn't correctly work.
Part Number: BQ25713EVM-017
Hello Support team,
I found the issue about uploading registers by using configulation file with BQ25713EVM and bqStudio.
The fail process is below
1. Powering EVM
2. Change only WDTMR_ADJ setting
3. Save Registers
4. Reset the device to default value
5. Load the file saved at #3, then the WDTMR_ADJ show changed Value
6. But it return to default value after clicking “Read Register”. That means that the loaded value is not write to device after just click “Load Register”
Could you confirm this?
Hirokazu Takahashi
