I would like to ask about the transformer direction between PoE and non-PoE.
Non-PoE ethernet application, I think typically common mode choke coil side of transformer is RJ45 (cable) side.
When PoE ethernet application, It seems common mode choke coil is opposite side of RJ45 (cable) side.
I guess above configuration would be typical for these use case. Is there implicit rule of transformer direction like above?
I guess transformer direction is opposite would be PoE transmit the power via cable so flowing current through choke coil may be not good in some reasons.
Would you let me know if there is an implicit rule for transformer direction?
Toshihiro Watanabe
