Hi Sir,
May I have your help to check is there any concern on below design specification with TPS63070?
1. Vin = 3.8V - 4.2V ; Vout = 4V / 1A
2. Vin = 13.5V ; Vout = 4V / 1A
Hi Sir,
Hi Teresa:
As the limited information about your application, I can't give much useful suggestion.
Please keep follow the guidance showed in datasheet, and take care about the effective value of the capacitance as the DC bias, and make sure the inductance has enough current capability. Additionally, the layout is also important to the performance.
Hi Teresa:
As long time not hear you, I assume you have solved the issue. I'll close this post.
If not, just reply below. Thank you~
