What does this mean?
"Value is beyond maximum value defined for parameter: Calibration.Current.CC Gain"?
What can I do to restore a right value?
Hi Marco,
That means the value you were writing into it exceeded what is allowed by bqstudio. To restore a correct value, reprogram defaults. To be careful, when you first get the gauge, export the default values into a gg so that you can import it if something goes wrong later.
