Hi TI Team,
We also checked the TPS23880EVM document. In page 2 of that document, it says:
“Two IEEE802.3bt (draft) 4-pair ports with 1000BASE-T (gigabit Ethernet data pass-through)”
That means that the EVM supports only 1Gb Ethernet.
Do you have similar or higher version of PoE EVM (Evaluation Module) that design to run in 10GbE?
In case none, do you plan to create one? Or can you recommend TI third party partner that has EVM that support 10GbE?
Appreciate immediate response.
Conrad
