Hi
My customer uses LMG3410EVM-018 jump to 225W PFC replace Mosfet,
the actual power can only reach 120W and Ids will stop for a short time,
The Fault also has drop, Is this a problem with EVM?
CH1:IN CH2:Fault CH3:VBUS CH4:IDS
Hi
Hi Bryan,
The EVM has been fully tested with no issues. What is the VDD voltage supply you are using? It looks to me it could be some UVLO fault. Could you please check on the VDD voltage to make sure it does not drop below the threshold?
Lixing
Hi Lixing:
The issue has been found,
as customer uses PFC PWM OUTPUT is 12V, need buck to 5V,
we use resistor divider, but the resistance value too large, lead to rise time too long,
change to ziner, the work is normal.
Hi Bryan,
This is great news. Glad you have found the issue and thanks for letting us know. Please let me know in the future if you need any help.
Lixing
