Other Parts Discussed in Thread: BQ25892
Do you have a coding example for BQ28Z610 ?
I am working on a advanced charging algorithm by using gauge ( BQ28Z610 ) in order to drive BQ25892 for charging a battery.
In addition to datasheet, is there a reference design to see sample code examples ?
First, I would like to initialize BQ28Z610 and BQ25892 .
Second based on given battery charging profiles, I would like to charge the battery based on current, voltage and age as shown in the following application document :
But I don;t see any coding example. There are only datasheets.
Is there a reference design based on a sample battery charging profile which shows the optimization of charging time while keeping the lifetime of battery the longest possible with the addition of battery age information which comes from Battery Gauge similar to BQ28Z610 ?
Thanks and best regards,
