Hi.
I'm working on a UPS and I need to prototype different battery chemistries solutions for backup. Backup is 12V 10W, 10Wh.
I have already a wide input/output buck-boost CC/CV for charging/discharging, but I need recomendation abot ICs for balancing, I2C/SMBUS gauging and protection.
Which ICs for a 2 to 5 Liion or LifePo4 would you suggest for pack protection, balancing and gauging? Is there any system compatible with these chemistries and Lithium Ion Caps?
Is it possible to configure BQ40Z80 for Lithium Ion Capacitors?
Which ICs provides the simplest configuration for balancing and gauging Liion
Can I use bq33100 with a supercap pack directly charging and discharging via a buck/boost?
