Other Parts Discussed in Thread: ISO1541
Hi sir,
As per our application, we are using TPS2388 IC for PoE communication. I connected the PSE controller and microcontroller with non - isolation system(i.e - SDAI and SDAO shorting together). If i shorting SDAI and SDAO to SDA line that time my SDA pin stuck LOW. Even I give 10K pull up on SDAO line also.
I isolate I2C connection between the PSE controller and Microcontroller, I2C both pins are getting High, due to pullup.
