The datasheet for this device shows the CS and COMP components being grounded at PGND rather than AGND. Is there a reason for this? Is it just layout convenience?
Michael
Michael
Hi Michael,
Thank you for considering LM5155. Could you provide the information where you see in the datasheet for the CS and COMP ground connection?
In the functional block diagram below, the PGND and AGND are tied togather.
Generally, PGND and AGND are electrically the same. However, we separate them for noise immunity purpose. I would tie the COMP to AGND to ensure a clean COMP signal. But the PGND and AGND are tied together at some point with a net-tie in your layout.
Yinsong
Hi Michael,
Sorry but I'm not quite sure what you mean by connect CS to AGND. CS is the current sense which directly get current from the sensing resistor of the power stage. If you are talking about the ground of the sensing resistor, that has to be connected to PGND since it is part of the power loop. And to help filter out the leading spike noise of CS, you can add the RC filter (R5, C19 in the EVM schematics), which is also mentioned in the datasheet.
Yinsong
