Other Parts Discussed in Thread: TPS7A47
Do we have any data on the PSRR vs frequency of the TPS51200 when operated in the simplified DDR application (as shown in the datasheet, front page, VLDOin to Vout with a constant REFIN).
OK - I'll attempt to measure
I don't understand why you differentiate the TPS51200 as a linear regulator vs. a switcher. Linear regulator do have PSRR specifications - check out the TPS7A47 for instance where we specify 78dB PSRR at 1k for 16V -> 15V / 500mA. Did I miss something that you intended to communicate
Hi Steve,
You are right.
Can you share PRSS test result in case other customer needs it in the future?
Qian
