BQ24079: BQ24079 design issue
Part Number: BQ24079
Hi Team,
Please help double check schematic, if there are other suggestions for modification, thank you
1. Output does not to be used,, is it need added bypass 4.7uF capacitor?
2. Status of the CE
  CE# to control the charger On/Off, like Spec., Is controlled by the switch to control CE# pin, . As shown schematic below, is the correct?
3. Detailed complete schematic, I can send message to  team for check.
thanks
Kevin
