battery charger with battery heater
hi,
we are working on a battery charger for a 1S pack, where we need to add a control that turns on a heater (embedded into the pack) if Tambient is <0degC.
we are looking for a standalone/complete analog solution (no MCU / SW).
this modules will be enabled and supplied by the charger when inserted (and not by the battery).
any advice is more than welcome, otherwise we would start looking for a discrete implementation
thansk a lot in advance
KR
Vincenzo
  • Vincenzo,
    It seems like for your application you would need a temperature switch. We have both pin programmable and resistor programmable temperature switches, which can send an alert to the system when a temperature threshold (0degC in your case) has been tripped.
    A few additional questions to select best temperature switch for your customer.
    • How many trip points of interest are there?
    • Is resistor programmable or pin programmable (factory preset) temperature switch preferred?
    Jalen
