Other Parts Discussed in Thread: LM5069
Hello. I have 2 questions regarding the TPS2492
1. Is there a lower limit for the timing capacitor?
I would like to have an overcurrent response time around 5-10 microseconds, as I am using this to protect a downstream 20KHz PWM motor drive circuit. Is this something the part can achieve? I calculate that it will require around a 33-47 pF capacitor.
2. Does the device behave to actively current limit (regulate) or does an over current detection over the threshold simply activate the timer?
Thank you, CHarlie
