BQ2084-V143: Is there a way to restart the chip via i2c bus
Part Number: BQ2084-V143
I made some changes to BatteryMode register by changing it to measure mAh to mWh. It looks like in register RemainingCapacity 0x0f the value is still in mAh. The chip is inside an enclosure and I can't change the circuit. Is there a i2c command that will restart the chip and force it to use the new parameter to measure in mWh?
