BQ27542-G1: Qmax Initial Value
Part Number: BQ27542-G1
Greetings,
In the procedure of generating a golden image, the second step is to set the right parameters in the data memory. In the documentation the minimal configuration requires the setting of the Design Capacity,
Taper Current, Discharge Current Threshold, Charge Current Threshold, Quit Current and Terminate Voltage; yet on reading this document SLUSC33-APRIL 2015 i found this statement :
"The initial Qmax values are taken from a cell manufacturers' data sheet multiplied by the number of
parallel cells. It is also used for the value in Design Capacity".
So do i need to set the Qmax value to, or is this done automatically by setting the Design Capacity alone ?
Tarak
