My customer has an issue with the BQ4050RSMR and has 3 questions.
1. How do I look at the status of the safety circuit? Which register should I look in? I need to know if an over-charge or over-discharge current has occurred.
2. How do I enable or disable the charging/discharging? What register is best to stop the charging/discharging?
3. How do I reset the safety circuit?
This will not be using the TI test box, but I will be writing SMB commands internally from the product (microprocessor) during runtime of the product. If you can help with the SMB format and what values to write to what register I would appreciate it.
Thanks for the support,
Kevin
