Other Parts Discussed in Thread: ADS1299, TPS61022
Hi I
I use ADS1299 with 3.7V lipo battery
Can you recommend me a boost? I will connect it only to the ADS1299
which Characteristics?
efficiency? ripple?
because tps61235P automatic detection between PFM and PWM
Dear Sir,
The efficiency is similar, but for the TPS61022 you can set it work at the FPWM mode, hence you can get very low output ripple. For the TPS61235, it works at the PFM mode at light load, so the output ripple will be higher.
