I'm starting a project for a battery charger made up of 5 modules. Each module contains, approximately (the entire battery pack composition is not yet defined), 140 lithium batteries in configuration 20S7P.
- Could I use the BQ24610 as battery charger?
- It charges only a series of 5-6 batteries and I have to charge many series of 20-25 batteries. Could I divide the entire battery pack in elementary cells made up of 5?
- If question 2 have an affirmative answer, how could I connect every device for a safe behaviour?
- I suppose I need a battery balancer. Which device do you suggest?
- Do you suggest other charger devices or configuration?
Any information, in this project phase, can be very useful so I encourage you to suggest your way to proceed.
Thank you for the support
Best regards
Piero Mistretta
