when I try to connect the battery pack to the IC (using the guide procedure), the BQ77PL900 often decides to destroy itself. The damage is ever in the corrispondence of the 9th pin. Can you suggest me a solution to make my design more safe or a probable cause of the fault??? The problem remains also if I use a 30 Volt generator limited in current(150mA) and a resistive voltage divider to emulate the battery pack. The BMS part of my board has the same layout of your demoboard....
thanks,
DG
