Other Parts Discussed in Thread: LP8863-Q1
My design goal with LP8867 is to be able to enable or disable individual LED rails on the go, with fault signal properly functioned. I have following design idea and would like some feedback:
- To disable a rail LEDn, disconnect the rail without tying OUTn to GND, and send a 10us reset signal to EN pin to clear the fault.
- To enable a rail LEDn, connect the rail and send 500us reset signal to EN pin.
- My questions is that not tying OUTn to GND is against the datasheet but I'm not sure if it creates a real problem in the long run.
Let me know if there is any concerns with this design or if you have better suggestions.
Borui
