BQ4050: GPC ERROR
Part Number: BQ4050
Hello, after uploading a zip file to the GPC tool,i recieved an email with the next report:
"computation wasn't successful, but the specific reason was not identified ' please check that all files are prepared  according to the documentation . the support personnel have been informed
the files were inserted here:
what could be the reason for this error ?
thank you .
hightemp_lowrate.csvlowtemp_highrate.csvlowtemp_lowrate.csvroomtemp_highrate.csvroomtemp_lowrate.csvhightemp_highrate.csv
NumCellSeries=3
CellTermV=2500
ChemType=1
VoltageColumn=3
CurrentColumn=4
TemperatureColumn=2
ElapsedTimeColumn=1
FitMaxSOC%=12
FitMinSOC%=6
LearnSOC%=7
  • Hello Victor,
    I have assigned this thread and an apps engineer will respond once we take a look. It should be within 2 days.
    Just an FYI, a tornado hit our GPC servers and they are currently down.
  • Victor,
    the issue is with the column assignment. Tool is using zero as origin, so count should be 0, 1, 2, 3....
    But in your config file you set:
    VoltageColumn=3
    CurrentColumn=4
    TemperatureColumn=2
    ElapsedTimeColumn=1
    Yevgen
  • thank you yevgen, after fixing the configuration file and running some more discharge tests i recieved the next error from the gpc tool:
    email report:27_10_19_CHEM.zip
    The following errors were reported by the calculation engine:
    Error: discharge data points less than 10, N=1 in file roomtemp_lowrate.csv
    Error: discharge data points less than 10, N=1 in file roomtemp_highrate.csv
    GPC _CEDV.txt:
    Warning: voltage in V detected, divider changed to 1
    MiscInfo:
    ProcessingType=CEDV
    i added the zip folder so you can take a look .
    can you find the reason for the error?
    thank you ,
    Victor
  • Hello yevgen, please ignor the previous question, the error has been solved ,
    Victor.
