BQ25898: Settings for registers
Part Number: BQ25898
If the VBUS power is turned off, will the settings be lost and return to default values?
What are the conditions for setting to default values?
  • Hi there,
    Either VBUS > (VBUS_UVLOZ) OR the battery voltage VBAT > VBAT(DPL), the register setting will be retained assuming the watchdog timer is not expired. The register setting will be reset to default values if the watchdog time is expired.
