Hi team,
About TPS43340-Q1's Low Power Mode, I have some questions. Could you explain when HS Switch will be turned off in Low Power Mode?
Datasheet says [Whenever the VSENSEx value falls below the reference, the high-side MOSFET turns on for a pulse duration inversely proportional to the difference across VIN-S2 for Buck 1 and VIN-S4 for Buck2. ], how this Ton can be decided? In some TI devices, there has a min peak current limit to decide Ton, here I am still confused how Ton can be determined.
Could you have some detailed explanation?
Thanks a lot,
Yang
