bq35100 detect EVE_ER34615 (19000mAh) lithium thionyl chloride (Li-SOCl2) battery
1、when I calibrate CC offset and board offset, the bqstudio report:Calibration- Current flow across sense resistor, Please ensure no current is flowing and retry calibration.
I get the info from:https://e2e.ti.com/support/power-management/f/196/p/785441/2912877#2912877
CC Offset and Board Offset are values which are changed during the calibration procedure using the calibration plug-in. These short across SRN and SRP internally and open SRN and SRP internally when 0 current is flowing to calculate CC Offset (Short SRN-SRP) and Board Offset (Open SRN-SRP).
Short and open SRN-SRP can do this to finish calibration for bq35100?
2、my battery :EVE_ER34615 (19000mAh) lithium thionyl chloride (Li-SOCl2) cel
Programming the chem id programs the OCV table and the resistance tables.
about these tables infos, Now I have a problem: OCV table and the resistance tables data how i can flash to my project?
when my project enter mass produce, I will have so many chips, I can`t flash it by bqstudio.
Programming the chem id programs only when I bringup the bq35100 chip.
how can i do?
thanks.
