The Turnon time(ton) is defined 3ms as max on the datasheet.
Could you tell what we should estimate about the typical value?
Thanks in advance.
S.Sawamoto
Thanks in advance.
S.Sawamoto
Hi sir,
You can refer to the datasheet page6 Figure2 which have the definition of Ton.
For TI's policy, I will first click resolved button.
If you have any other concern, contact me any time.
If you think resolved, please help click 'Issue is solved button'.
Thanks.
Thanks for the quick reply, but it doesn't answer for the question.
I'd like to know what is the typical value. In other words, how much variation we should consider.
Regards.
Hi Sir,
I have a check of the Char data.
The typical value is 2.441ms.
Thanks.
