CCS/BQ40Z60: Is SoH saved when it is updated?
Part Number: BQ40Z60
Is the SoH or the data it is calculated from saved as it is calculated, or possibly not dependent of historical values? I'm trying to find out if the SoH can be expected to remain accurate even after the BQ40Z60 has been put into shutdown mode and the device it is connected to is completely turned off for some time before being woken back up as the device is turned on again. Or if looked at the other way around, if there is some delay or number of cycles required after exiting shutdown before the SoH becomes accurate?
Andreas
