Hi, Team
this is MASA.
could you see below ?
Q1. should customer consider how much Cout is ?
-> i do think so regarding ripple at output. correct?
Q2.is there equation to select how much its value is appropriate?
Q3.
is there any way to do something around the IC with external component if loop compensation inside IC were not good enough.
Q4.
How IC compensates loop internally ?
is there any apps note or any image to know how those work?
