UCC27511A: 80W Gate Driver at 40MHz
Part Number: UCC27511A
Hi team,
A customer is looking for a gate driver for an 80W HF application at about 40MHz. So they are looking for a small bandwidth, high power gate driver. Can you recommend a part?
Thank you,
Franz
  • Hi Franz,
    Thanks for reaching out.
    Assuming 40MHz switching frequency, and gate drive voltage <=5V (please confirm or correct me if I am wrong) to drive 0V referenced FETs, the devices below would be a good starting point.
    You can find more on the link below and sort out by isolation requirements (I believe this application does not require isolation), topology (half-bridge or low-side) and gate charge, expected rise/fall times and gate drive voltage.
    http://www.ti.com/power-management/gate-drivers/overview.html
    Please let us know if you have additional questions or press the green if this addresses your inquiry.
    -Mamadou
