Other Parts Discussed in Thread: TPS65381EVM
We measured ttri and td1 as below, the measured delay time is much more than our spec, could you please help if these are normal and any risk? Thanks.
Hi Wayne Liu,
I will try to reproduce the behavior you have describe above. Could you please provide additional information regarding your test setup.
Are those captures from a TPS65381EVM?
Ivan
Hi Wayne Liu,
Thank you for the clarification. I reviewed the oscilloscope images you sent and I have a couple of comments.
With respect to ttri:
With respect to td1:
Ivan,
Thank you, this is very clear.
Just double confirm, so my waveforms are normal and match the datasheet, right?
Wayne Liu,
Based on the scopes shots you have provided, I don't believe ttri and td1 are out of spec.
