Hi team,
I would like to find an alternative source for NCP431BVSNT1G (ON)? Whether The MPN could PIN TO PIN compatible with NCP431BVSNT1G? Tks a lot.
Voltage regulator_ON_NCP431BVSNT1G.PDF
BR,
Xiaobing (Eric)
Hi team,
BR,
Xiaobing (Eric)
Hi Xiaobing,
This is a great spot for the new TL431LI. We are pin-to-pin capble and also operate in an A and B grade, as you can see in the datasheet. Please let me know if you have any issues with part selection. Does your application require the 100mA output current?
Abhinav.
Hi Xiaobing,
You're right, this is a difference between these parts. This new part has a tradeoff of output current for benefits in Iref, Ii(dev), and temp drift. If you need the 100mA sink current, please take a look at the TL431, which is a different part number but functionally equivalent to the NCP431.
Abhinav.
This is alternative source PN TL432BQDBZR, maybe it will help someone in future.
BR,
Xiaobing (Eric)
