Hi team,
My customer considers TPS92691 for following usage.
Input voltage: 24V
Output voltage: 36V
Output current: 2.3A
LED lighting control: output 2.3A/1ms pulse with arbitrary timing.
Does below setting work correctly in order to realize " output 2.3A/1ms pulse with arbitrary timing" operation?
Set ILED=2.3A
Drive PWM pin above 2.3V for 1ms
I'm looking forward to hearing back from you.
Shota Mago
