Other Parts Discussed in Thread: BQ24618
I'm having trouble understanding how the components around the CHG FET are supposed to be selected. In the detailed example, it says load removal is necessary, but then later it says that because attaching a charger is acceptable, a 1-Mohm resistor is ok for R_GS_CHG. However, in the simple example table, it says that a 1-Mohm R_GS_CHG disables load removal for recovery from UV fault. I'm trying to design a system where the battery is a fixed component of the system, so the only way to recover from a UV fault should be attaching a charger.
