As per REG03 we expect SYS to turn off when the battery drops below SYS_MIN (BTE, we keep default setting of 3.5V).
However, when we tested by draining the battery we found that the battery was still connected (SYS voltage was the battery's 'loaded' voltage) of 2.8V,
When the battery was disconnected and the voltage measured it was 3.3V
We expected SYS to turn off when SYS_MIN was reached. Of course, this is only a concern when we are NOT charging
the battery, otherwise the battery charging use case is shown in the data sheet in Fig. 10.
If SYS does not turn off to stop battery depletion using this then how is it properly done?
Thanks in advance,
Kevin Kreger
