BQ24715: Charge current setting
Part Number: BQ24715
I need to charge a 3s2p configuration pack. The range is given as 128mA to  8.128A. My charge current is 3.25A. how do i set the charge current to 3.25A ? We are using Panasonic NCR18650B li-ion batteries which can only support 0.5C maximum charging current. Can you suggest anything regarding this?
Can i set the charge curent  as ChargeCurrent() = 0x0cb2H?
Please find the attached link for data sheet of the battery.
https://www.batteryspace.com/prod-specs/NCR18650B.pdf
Thank you
Harini Krishna
