Hi team,
we want to check how to connect the GND and PGND. how about connecting the GND with the red circuit, and PGND with red squar? Thanks.
Hi team,
Hello Frank,
You are correct except for the following recommendation.
I would connect the lower resistors on LINEOV and LINEUV to GND.
Then pin 8 (GND) connects directly to pin 13 (PGND) as described in section 11.1 of the UCC2897A data sheet
John
Hi John,
thanks. i also re check the datasheet layout example as below.
pin 1 GND
PIN2 GND
PIN3 GND
PIN4 GND
PIN5 GND
PIN 6 GND
PIN 9 GND
PIN10GND
11 GND
12 GND
17 pgnd
18 19 GND
