Hi team,
I would like to measure loop stability of TPS61169 with FRA. Could you share connection example if we have?
Kotaro Yamashita
Hi team,
Kotaro Yamashita
Hi Sean,
Thanks. Does RFB mean RSET? e.g. 10.2Ohm on Figure4
In this case 50Ohm seems too high compare with 10.2Ohm RSET. Is that correct?
Kotaro Yamashita
Hi Kotaro,
50ohm is ok, You can adjust the amplitude of small signal through this 50ohm to aviode interption, for example ~10mV.
Sean
