We are using TPS40210 to generate 26V supply from 15V input.
Sometimes, we found that the output can't reach to 15V. There is no voltage spikes on pin-7 ISNS for overcurrent detection observed. But we do see that the regulator pin-2 SS is oscillating, meaning it is resetting the output continuously.
Is there any other situation under which TPS40210 resets its output even without output over current?
Peng,
