Other Parts Discussed in Thread: INA3221,
We have the TPS65023B designed into a board and need to determine current on the three VDCDC rails.
I don't see an I2C register to do this. I know there have been undocumented registers with other TI parts. Is there a way to determine current by reading the I2C registers?
If we can't use I2C to determine current, then what's the TI recommended way to measure current with a scope & voltage probes using measurements across the inductor and cap? We're using the same topology as shown in the first page of the datasheet and used on the TPS65023B EVM.
Thank you,
Bob
