Charge to 50%, When the battery is relaxed for a few hours, the RSOC become 0.
How do you configure the RSOC to prevent it from going to 0? Thanks
Hi Jason,
Have you programmed a ChemID into BQ40Z80? Also, have you run the learning cycle?
Refer to the app note below.
http://www.ti.com/lit/an/slua848/slua848.pdf
Andy
Hi Jason,
The learning cycle is critical for the gauge to perform correctly. Have you been able to run the learning cycle successfully?
If not, let us know what kind of issue you have seen and we will give you some help.
Andy
Hi Jason,
As I mentioned before, the learning cycle must be run in order to make sure the gauge device can operate properly.
I would suggest you take a look at the app note I provided before and run the learning cycle.
If the learning cycle fails, provide your log file and gg file and we will try to help you find out what might be the cause. Thanks.
Andy
Hi,Andy
The battery I'm using doesn't have a matching chemical ID, so it won't work.
We just want to use the coulometer part of the chip right now.
Thanks.
Hi Jason,
I suggest you use the GPCCEHM online tool to get a matching chemistry ID for your battery.
http://www.ti.com/tool/GPCCHEM
Andy
Hi,Andy
Already used, no matching chemical ID
Thanks.
Hi Jason,
Can you share with us the file you submitted for matching chemistry ID and also the report you received? Thanks.
Andy
It's report.
Chemistry ID selection tool, rev=2.48 Configuration used in present fit: ProcessingType=2 NumCellSeries=1 ElapsedTimeColumn=0 VoltageColumn=1 CurrentColumn=2 TemperatureColumn=3 Best chemical ID : 705 Best chemical ID max. deviation, % : 37.26 Summary of all IDs with max. DOD deviation below 3% Chem ID max DOD error, % Max R deviation, ratio 0 0 0 Accuracy Error: Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule * Warning: First OCVpoint has non-zero current I= -0.15 Please make sure you have a 2 hr relaxation period before the beginning of discharge. * Warning: Last OCVpoint has non-zero current I= -0.15 Please make sure you have a 5 hr relaxation period after the end of discharge. Selection of best generic ID for ROM based devices like bq274xx Device / Family #1 Generic Chem ID Device/ Voltage/ Chemistry max DOD error, % 312 bq27421-G1B: 4.3V LiCoO2 100 354 bq27411-G1C: 4.35V LiCoO2 200 3142 bq27421-G1D: 4.4V LiCoO2 200 128 bq27421-G1A: 4.2V LiCoO2 200 Best generic ID 312 Warning: Generic ID Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule Device / Family #2 Generic Chem ID Device/ Voltage/ Chemistry max DOD error, % 1210 bq27621: (ALT_CHEM1) 4.3V LiCoO2 100 354 bq27621: (ALT_CHEM2) 4.35V LiCoO2 200 1202 bq27621: (default) 4.2V LiCoO2 200 Best generic ID 1210 Warning: Generic ID Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule Device / Family #3 Generic Chem ID Device/ Voltage/ Chemistry max DOD error, % 3230 bq27426: (default) 4.35V LiCoO2 100 3142 bq27426: (ALT-CHEM2) 4.4V LiCoO2 200 1202 bq27426: (ALT_CHEM1) 4.2V LiCoO2 200 Best generic ID 3230 Warning: Generic ID Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule Warning: First OCVpoint has non-zero current I= -0.15 Please make sure you have a 2 hr relaxation period before the beginning of discharge. Warning: Last OCVpoint has non-zero current I= -0.15 Please make sure you have a 5 hr relaxation period after the end of discharge.
I think there should be something wrong with your IVT file you submitted.
Check the following app note.
Hi Andy
Do you have any good Suggestions.
Hi Jason,
An accurate state of charge prediction depends on a proper chem id. Without the correct chem id, the RSOC reading the gauge reports will NOT be correct.
Andy
