Part Number: BQ4050
Other Parts Discussed in Thread: BQ40Z50
Need clarification on circuit for BQ4050 and external FETs for cell balancing. BQ4050 Datasheet refers SLUA420A for details, but said document is not compatible or usable with BQ4050. Found a thread .. e2e.ti.com/.../342036 Here is detail on the BQ40Z50 ... not quite the 4050, but answers provided are conflicting. I have chosen the solution as per this link... e2e.ti.com/.../Ext.-Balance.JPG However further discussion would indicate that this solution may not work and a proposed schematic using P channel and N fets is the correct solution. However, as discussed that solution required a firmware update in the BQ40Z50 to work ... which is not available as far as my understanding goes, with the standard BQ4050. Hence I need clarification as to what circuit is correct.
