BQ40Z80: Migrating from bq40z50 to bq40z80
Part Number: BQ40Z80
Other Parts Discussed in Thread: BQ40Z50,
Hello!
I'm planning to migrate from bq40z50 to bq40z80. Can You tell me, are there any pitfalls or problems that I can face with on configuration stage?
For example may be some difference in registers or setting device up?
Thank You
  • Allow us to take a look at your question and then get back to you.
    Andy
  • Hello Arsenii,
    I recommend you look at the TRM register map. It is important to make sure the registers you read are compatible. Other than that, please order a few EVMs and the upgrade process is just to keep the same chemID, run a learning cycle, but the other configuration registers are slightly different.
    Cell count for example will be different. I would also recommend you verify the protection schemes on both ICs to make sure the thresholds are the same. It is slightly different between the z50 and the z80.
