Other Parts Discussed in Thread: TPS2HB35-Q1
My customer is evaluating TPS1HB35-Q1 (Version C) and wants to set the clamp current limit at 2.3A.
Based on the current limit specs for Version A and B, they are concerned the clamp current will be too wide for Version C.
The MAX/MIN limits are around +/-25% of TYP value for Versions A and B, but this is specified over the -40C to 150C.
Do you have the same ICL and KCL spec data for Version C? Do you have any ICL and KCL characteristic plots over PVT corners?
Alan Ocampo
Analog FAE
Texas Instruments
