I have found on several registers, that Address Offset with a byte increment value & physical address. I cant able to understand for what this term byte increment is used for.
Ex: for CFG_BOOT register, it has mentioned as
Address Offset
Physical Address :
Description :
Type :
How we need to access the CFG_BOOT register in this case?
What is the link to refer the linux open source code?
RW0x0000 003B–0x0000 003B Instance :POWERPM_MASTER
