BQ24450 charging complete lamp signal?
Hello everybody
I´m a new designer and i´m trying to implement the bq24450 in order to charge a lead acid battery 6V;6Ah.
I want to turn on the charging complement lamp. But which pins should I use?
I can't use the STAT2 pins. Because the pin is turned off VBAT-VBI.
Please let me know how to do it.
We are waiting for your reply.
Best Reagards,
  • from the d/s, there's no special pin to indicate charge complete status for this lead-acid charger. STAT1/STAT2 are used to indicate the BUCK/BOOST/FLOAT as listed in pg7. We can take the FLOAT as charge complete and both STAT1 and STAT2 are OFF. There's detail application information start from pg8 of d/s.
