TPS22976 datasheet table 4 shows typical rise time value.
My customer would like to know roughly +/- how much variations it would have after considering over all temperature range and device process variation.
K.Hirano
K.Hirano
Hirano-san,
We only provide typical specifications for timing as timing is dependent on the Ct pin, the input voltage and the loading condition of the use case. The typical time is the typical accounting for temp variation and process variation.
Thank you for your response.
My customer would like to know roughly +/- how much it would have after considering over all temperature range process variation for especially only the following two cases.
Case#1
3.3V, CL = 0.1 μF, CIN = 1 μF, RL = 10 Ω, CT_1000pF
Case#2
3.3V, CL = 0.1 μF, CIN = 1 μF, RL = 10 Ω, CT_10000pF
Could you estimate the variation % for each cases, please?
K.Hirano
Hirano-san,
I assume that 3.3V is the input voltage. What is the bias voltage in this case? The bias voltage has affects the timing characteristics.
Shreyas
My customer is connecting VIN and VBIAS.
So, VIN = VBIAS = 3.3V.
K.Hirano
Hirano-san,
We can run some simulations and get data.
This timing data is not to be used as a guaranteed but only as a design reference.
Unfortunately, running these simulations may take a little time so I will get back to you early next week or before with the data. Apologies for the inconvenience.
Could you please email me directly at s-dmello@ti.com? I would prefer to take this support from E2E to email.
