Hi Expert,
Our customer has one question about Alert pin.
We know Alert pin should be connect to host MCU GPIO port if AFE server as an active high interrupt.
However, Sometimes the GPIO has an high signal by unknown condition to cause OVRD_ALERT bit set then C/D FETs off after .
Customer would like to add diode to GND or level shift circuit, do you think it is available for this case? or do you have any recommendation for improvement?
