Hi there
We are currently working on a battery powered project. For this we used the bq40z80 fuel gauge to measure remaining capacity and also to protect the battery from overvoltage and undervoltage.
Our problem is that we cannot get the gauge to do anything. It doesn't respond to SMBus reads or writes(no ack) and it also doesn't open the protection FETs to allow the battery to be drained, even though the battery is fully charged. But of course we were unable to tell the bq40z80 the cutoff voltage levels because the SMBus connection is not working.
Can you please explain in more detail how to do the initial setup and please also explain how to program the levels using the bqStudio and ThumBus2300 SMBus adapter.
PS: I attached the circuit arround the bq40z80. Its nearly identical to the one of the EVM.
Thanks for your help.
Regards André
