Hi Team,
Due to the latch funtion of OC pin, we must pull high over 2V, so we add external circuit to accomplish it,
pls let me the rating of OC pin, due to the datasheet no describe this.
thank you
Dear Hong,
I am planning to use an other over-current sensing method than proposed in application notes. I am going to us an aux FET to switch the half-bridge node to the OC pin, when the lower FET is on, see the following schematic:
J3 goes to OC pin. Is D3 necessary, or there is built in diode (or zener diode) on OC pin?
I know I will need good timing, the aux FET wil have a very low Gate charge to ensure its fast turn off before Q3's turn off.
