I'm using a 103AT 10K NTC type thermistor and would like to set Rth_cold and Rth_hot to 10 and 45C instead of 0 and 45C as per your example in the datasheet. I worked through the math for the equations Rt2 and then Rt1 for your values of Rth_cold and Rth_hot correctly but then used my values of Rth_cold and Rth_hot and ended up with a negative value for Rt2 ... any ideas why ?
Thanks.
